Hi everyone,
I do not understand how to use sun and skylight to get good render results. Renderings with both sun and skylight (without custom environment) are way to bright. Is it possible to get good results combining sun and skylight?
The only option I found to tweak is the intensity of the skylight, but this option is only available if a custom environment is used. Wouldn´t it be useful to be able to adjust the brightness of the sun and the skylight? Or to adjust the sensitivity (iso) of the camera?
It would be a useful feature to be able to change the intensity of both the sun and the skylight independently, so that you can adjust the hardness of the shadows and get results that could be “between” the two extremes (only sun or only skylight).
(AFAIK this is possible in Vray and really useful.)
