I’ve got a tabbed dock bar woking. It is registered in the way the sample shows:
Now, I’d like to access an item in the dock bar in RunCommand function. How can I get the object?
Thanks,
Thanks,
Hi @takahashi-kazu,
When your panel is constructed, you might want to assign the instance to some variable on your plug-in (or somewhere) so you can access later…
// Set the user control property on our plug-in
MyPlugIn.Instance.Panel = this;
– Dale
