How to get 2D export to Inkscape at high quality?
The AI file format does not work. I exported from Rhino having selected “Save Geometry Only”, assuming that this creates a very simple AI file.
When I import into Inkscape 0.48 / Windows 7, that fails with error messages:
  • Adobe Illustrator 9.0 and above (PDF based):
    Failed to load the requested file C:\Temp\logo.ai
  • Adobe Illustrator 8.0 and below (Postscript based):
    1. UniConvertor failed
    2. Failed to load the requested file C:\Temp\logo.ai
It seems that:
  • Rhino exports to Illustrator 8.0 and below format.
  • The tool UniConvertor conversion tool used by Inkscape has issues on Windows 7. See comments on Inkscape bug 745997. Inkscape 0.48 includes UniConvertor 1.1.5.
    A recommended workaround is to install UniConvertor 1.1.4 separately, and then do the conversion manually from the Windows command prompt:
    uniconv input.ai output.svg
    I have not yet tried that.
