How to Form Surfaces in Between Series of Lines?
Hello guys, im trying to create a surface between these curves, the first partitioned list provided a result
wondering how to proceed from here
any help is appreciated!, thank you
gradient wave descent landscape.gh (31.1 KB)
If you want to learn something, I’d suggest the Relative Item component…
Thank you @Volker_Rakow , Helpful!
Can you show just for fun? :eyes: :upside_down_face:
Jk @martinsiegrist
gradient wave descent landscape.gh (40.6 KB)
Split tree afterwards is just to illustrate
@Vasanth_C, Volker had shown you a proper way as well, but were you intending to get those in-between surfaces in addition to the other ones you already had or both series? In any case the RelativeItem suggestion by Martin seems to take care of both.
:slight_smile:
Because the starting point is essentially a grafted flat list, there is nothing you could do with Relative Item that you couldn’t do with List components. Put another way, there is no mask you could make for Relative Item that would make use of index. You could just aswell flatten the list from the start. The two methods below are equivalent.
Never flatten that’s for quitters :winking_face_with_tongue:
Jokes aside,
yes :+1:
The most likely solution for a beginner:
