I am planning to design a 3d plane from 2d. Here i am planning to make 4 curves on a rectangular plane and bend it downward to make a simple chair/stool. I have seen some tutorials , but doesnt worked ou well. In the latest tutorial video using crane plugin, its seems bit easier. But doesnt run well. I uploaded small paper prototzpe and the incomplete gh file. If anz one could help me in this, it would be helpful
Grahopper_ 4curve structure_ trial 1 wirh crane.gh (29.3 KB)
Grahopper_Test_2_ 4curve structure new method latest kangaroo.gh (23.6 KB)
please find this gh file. Instead of bending the plane is rolling. How can i solve it. Anyones help would be grateful.
I think your mesh is not suitable for this. Instead, I would use a triangulated mesh with edges along the creases
You can constrain the four corners on the XY plane and the result looks like this:
I modified your arcs slightly so the surface is split into five segments.
Grasshopper_Test_2_4curve_mrtn.gh (27.0 KB)
I did it with Load , EdgeLength and a little bit
remeshing …
Justin_01.gh (18.6 KB)
