Hi
First I use Tween between two curve
Then Divide Array of curve
Check Curve Seam
Then run Panel Custom 2D
How can I fix twist?
chestnut - rhino 6.3dm (439.6 KB)
Thank
Travis
Hi
Thank
Travis
I think this is a bug to the command _ptGridUCurves, I will make a YT to it.
Here is a GIF tutorial about how to fix it, wish it will be work to you.
I put together a clip repeating your process and the result came out as expected. Did I miss something?
Interesting, now I know the issue from order
Thank for your advice.
