Might need more information.
That sweep looks sweet! Not sure if that one line is supposed to be so 3D though.
Not sure which object is of concern here, maybe this curve…
Oh I see, your image is a side view of that curve. Now it looks less 3D than it did at first glance.
So you’re tryna sweep a circle into a square or somem…
Yeah I don’t think this is a simple lofting operation. But I could be wrong, someone might have a fancy GH way of doing it.
I said loft but I mean sweep idk
Move the end of your sweep curve so that it hits the edge of the circle. In the Sweep1 command, pay attention to the “Drag Seam Point to Adjust” prompt. You may have to flip one of the 2 arrows to make them face the same direction. You got this!
ive tried everything i cant figure out why
nico engagement ring 234.3dm (2.0 MB)
I think I tried that too though.
i need help with this to look like this
draw these curves, and use sweep 2 don’t try and do them with sweep1. see how they self intersect? …if you draw them correctly then use sweep 2 it won’t do that.
good curves = good surfaces
thank you so much i literally just figured this out as well after spending so many hours on my laptop but perserverance pays off: thanks everyone for your help
happy to help, it may be useful for you to go thru the level 1 and level 2 manuals included in rhino under help>samples and tutorials>level 1 pdf and level 2 pdf.
many new folks skip these but time spent going thru them is never wasted and will make you better faster.
also make sure and check out our you tube channel
