Hey! So I’ve been trying to create a 3d printable mold to cast concrete (it’s a labubu, don’t ask) but the model I’ve imported is full of little imperfections that will make casting likely impossible. Is there a quick way of fixing these? I’ve tried creating a tapered curve from the edges (pic 3) but I can’t seem to figure out how to blend it gracefully into the main model.
Anyway, thanks in advance
Privide a simple NURBS model workflow for your reference:
- Use the
DraftAngleAnalysisto creat theMax Draft Curve - Extrude a surface or polysurface with a draft angle based on the
Max Draft Curve - Use
BooleanDifferenceto remove areas with undercuts.
This is a basic workflow. If the model is complex, especiall when the parting surface is not a simple plane, this process will require more patience and additional steps.
Also if you’re printing a master and using that to cast silicone molds then you can get away with some undercut.
Oh that’s perfect! I missed the draft curve option.
Thank you very much!!.
update: ok I tried it but the draft curves self-intersect and create weird shapes which cause the booleansplit / booleandifference to fail. Will keep trying.
Could you share your 3dm file?
