How to find X,Y intersection on an object with radius edges
When I want to move an object by selecting the back left corner of the object to 0,0,0 coordinate I just pick that corner on an object and use the move to 0,0,0
However when I have that same object that has radius edges on the corners I have to draw lines on the back and left edges on the object to find where they intersect ( See attached example )
Is there an easier way to find that point out in space on an object with radius edges?
Thank You!
KentExample Object.3dm (92.9 KB)
Hi Kent -
You can use point filters to first set either x or y and then snap to the other.
You could use BoundingBox with output=curves maybe.
Or use Connect to find that intersection.
You could do this with BoxEdit with the “use bounding boxes” option as well.
-Kevin
Another approach might be to use the center snap on the corner arc and move it to radius, radius instead of 0,0.
Thank You everyone for your suggestions…
I tried the “use bounding box” option and that looks like that’s going to work.
However I can’t figure out how to turn the bounding box OFF afterwards?
I just figured out that the bounding box is an actual set of lines that can be deleted… ( verses turned off )
Thanks again everyone for your suggestions… ( I’m going to also try the other suggestions to see which one is the quickest to use on a regular basis )
Why not have yet another method - for a box, you can use the Along osnap (where I type ‘a’ in the clip) to place a point:
For less conveniently aligned edges the Line command, with Extension option will get you there:
Thank you very much Pascal… This will be a great option…
Dear @kentdesautel
In such a situation why not using the available underlying data ?
  • Click on the 2D entity to display the Cp’s
  • Snap on the desired CP
  • Move the object from that Location
Regards
Rodolfo Santos
