Hello, I am trying to use the mosquito plug in to run a water level simulation and it needs a surface. I have my terrain as a mesh so I am using DeMesh and SurfaceFromPoints. The SurfaceFromPoints (SrfGrid) needs a U value / U count that I have to enter with a number slider. But it gives an error to me "UCount Value is not valid for this amount of points.
I have a total number of 3466 points in my mesh and I used this before with a similar terrain and it was easy to try and found the right U Count value, it worked before. But in this one I cannot find the right UCountValue at all.
I dont know is spesifically there is only 2 dividers of this number which is 2 and 1733.
I hope someone can help me here, thank you in advance.
PS: If you need an explanation for the attachments. I have 2 terrains inside, one is the existing and the other is the proposal. I need to use the plugin for both to see the comparison. The excluded parts in the model are the river course.
before after grasshoper agriculture.gh (278.0 KB)
Model_Agriculture_before after.3dm (3.9 MB)
