How to find the first obj after insert by RunScript
Hello all,
I insert a Block and I want give him some Usertext infos.
But I can´t get the first RhinoObject.
public static void mycommand(string script)
        RhinoApp.WriteLine(script);
        RhinoApp.RunScript(script, true);
This worked well but ,
public static Rhino.DocObjects.RhinoObject first_obj(RhinoDoc doc)
Rhino.DocObjects.RhinoObject first;
first = doc.Objects.First();
        return first;
but this find one Block only if I run the script two times.
so I think after run scrip I need somethink so this first_obj can work well ???
You have to add 2 things to your “script” I think. Add at the end:
 _selnone _sellast
with this your new created item will be selected. After this you can get the selected item with:
Dim go = New Rhino.Input.Custom.GetObject
go.EnablePreSelect(True, False)
go.EnablePostSelect(False)
Dim res As Rhino.Input.GetResult = go.Get()
If (res = Rhino.Input.GetResult.Object) Then
Dim objRef As Rhino.DocObjects.ObjRef = go.Object(0)
Dim obj As Rhino.DocObjects.RhinoObject = objRef.Object()
End If
The user will not be able to select more objects or another one.
(Sorry I only know how vb.net works but it is almost the same. Think you will be able to translate it :))
Thanks jordy,
but _selLast give you not the Last it give you all you create in the plug-in.
If I insert a point by
my_id = doc.Objects.AddPoint§;
I can find this point as the first object.
so I think Insert the block by the scrip metode is not the best.
so I have to find a way read a file and insert by
my_id = doc.Objects.AddInstanceObject(index, xform);
but I don´t know how to read a 3dm-file and find the index
Thanks Robert
to create a block see:
So that means block information is used in:
doc.InstanceDefinitions
and can search by name with:
doc.InstanceDefinitions.Find("blockname", False)
If you want to test this use:
Dim MyBlock As DocObjects.InstanceDefinition
MyBlock = doc.InstanceDefinitions.Find("blabla", False)
MsgBox(MyBlock.Description.ToString)
Give your block a name like “blabla” use a description and let it return to you :wink:
