How to find object by user string
Hi all,
how can the object can be found by key or value after SetUserString
import Rhino as rh
import scriptcontext as sc
x.SetUserString("Key","Val")
Thanks in advanced
I think you have to loop through all the objects to find it again:
You could create a dictionary to keep track of the guids otherwise, indexing by a tuple (key, value) for instance
Do you mean like this
Or can you post a small example how you would create a dictionary
I was thinking more of kdic[k] = id and vdic[v] = id
Or assuming you have multiple objects with the same key:
If not k in kdic:
    kdic[k] = [id, ]
else:
    kdic.append(id)
