How to script a component that finds if two or more breps are adjacent one to the other?
I need to script a component that assesses if two or more breps are adjacent, they need to have at least one surface or part of it touching but they do not have to intersect. I tried using the Intersect and IsPointInside methods but I couldn’t find a solution.
Hi Federico,
I have modified the function rs.IntersectBreps() a little. This code should print whether the selected breps intersect or not.
I am not the best Coder out there, so maybe someone has a better solution
import Rhino
import Rhino.Geometry as rg
import scriptcontext as sc
def Main(tolerance = None):
brep1 = rs.GetObject("Select the first brep", rs.filter.surface | rs.filter.polysurface)
if brep1:
brep2 = rs.GetObject("Select the second", rs.filter.surface | rs.filter.polysurface)
if brep2:
brep1 = rs.coercebrep(brep1, True)
brep2 = rs.coercebrep(brep2, True)
if tolerance is None or tolerance < 0.0:
tolerance = sc.doc.ModelAbsoluteTolerance
rc = rg.Intersect.Intersection.BrepBrep(brep1, brep2, tolerance)
if not rc[0]:
return None
out_curves = rc[1]
out_points = rc[2]
if out_curves or out_points:
print("The breps intersect")
else: print("The breps do not intersect")
if __name__ == "__main__":
Main()
