Dear all,
This is my first topic posted, hopefully my explanation is clear enough for those who are interested.
I’m working on making a cluster to generate probe points on a list of untrimmed surfaces by SDivide -> distinguish the direction of longitudinal axis for each surfaces -> Stream-Filter -> List-Item.
While tested with one surface a time, this cluster worked well; however, when tested with a list of surfaces, the element Stream Filter did not generate a list of combined item numbers as expected.
I am of entry level with Grasshopper, although I’ve some practices. But this is a work of modeling in my research study that I have to complete it. Any help will be appreciated.
No internalized geometry? (“Untrimmed Surfaces”) And flattening that input is probably not a good idea? Though I see that you immediately graft it in the next component, SDivide. I started on something but don’t have time right now to do a thorough job.
Nice work @HS_Kim, especially because it doesn’t use plugins! Bonus points for that.
I knew it was too complicated but didn’t have time to get into it. Thanks for making it simple (and still readable in R5).
Thank you very much @HS_Kim for help correcting it, and your kindly revising. I’ve learned a lot from your work, it is perfect to me.
I hope someday I will be able to help others here, too.
