Maybe is a dumb question, but as beginner I don´t find a fast solution.
I need to extrapolate from one/multiple surfaces (like windows), always a reference point on the central axis, wich is distant X cm (per Example 0.30cm), from the bottom line of the surface.
this is a very good solution, I just have to be careful that the surfaces are all built in the same way, otherwise it does not match the side of the surface from which to extrapolate the point.
