Hi
Does anyone know how to extract the "Visible Index " for each visible curve like the Make2D component , this for further branching retrieving in the “flatten” Make2D
Hi @MiguelBaron,
When adding geometry to a HiddenLineDrawing
, do so like this:
for i in range(0, len(inputGeo)):
hd.AddGeometry(inputGeo[i], i)
where i
is a tag you can use to find the source object later.
Now, when enumerating the HiddenLineDrawingSegment
objects produced by HiddenLineDrawing.Compute
, you can retrieve the tag, or index, of the source object from a segment like this;
obj_index = -1
obj = seg.ParentCurve.SourceObject
if obj:
obj_index = clr.Convert(obj.Tag, System.Int32)
# todo: add obj_index to some list...
Note, you’ll also need to import these two namespaces:
import System
import clr
– Dale
