I have a surface and some lines on the surface, then I use a cutting plane to cut the surface and the lines. Points (ptList) are created when the cutting plane intersects lines, and curves (curves[]) are created when the cutting plane intersects the surface. I would like to create line segments passing through the points (ptList). I’m having trouble to get all intersection points (ptList) with the following code. Thanks, Ming
var rc = Intersection.BrepBrep(brepPlane0, brep0, TOL, out Curve[] curves, out Point3d[] points);
//Join curves
var output = Curve.JoinCurves(curves, TOL);
SortedDictionary<double, Point3d> t2Pt = new SortedDictionary<double, Point3d>();
foreach (var curve in output)
foreach (Point3d pt in ptList.Reverse<Point3d>())
double t;
if (curve.ClosestPoint(pt, out t, 0.5))
t2Pt[t] = pt;
ptList.Remove(pt);
int k = 0;
Point3d pointFrom = Point3d.Unset;
foreach (KeyValuePair<double, Point3d> kvp in t2Pt)
Point3d pointTo = kvp.Value;
if (k > 0)
Line l = new Line(pointFrom, pointTo);
var object_id = doc.Objects.AddLine(l);
var rhino_object = doc.Objects.Find(object_id);
rhino_object?.Select(true);
pointFrom = pointTo;
k++;
The first picture shows a line passing through all nodes, but didn’t break them up. The second picture shows two points on the curve were not found by ClosestPoint()
I think this is what you want. Let me know if I am wrong.
// Select cutting planes
var go0 = new GetObject();
go0.SetCommandPrompt("Select cutting planes");
go0.GeometryFilter = ObjectType.Surface;
go0.SubObjectSelect = false;
go0.GetMultiple(1, 0);
if (go0.CommandResult() != Result.Success)
return go0.CommandResult();
// Select stiffeners planes
var go1 = new GetObject();
go1.SetCommandPrompt("Select stiffening curves");
go1.GeometryFilter = ObjectType.Curve;
go1.SubObjectSelect = false;
go1.EnablePreSelect(false, true);
go1.DeselectAllBeforePostSelect = false;
go1.GetMultiple(1, 0);
if (go1.CommandResult() != Result.Success)
return go1.CommandResult();
var tolerance = doc.ModelAbsoluteTolerance;
// Process each cutting plane
for (var i = 0; i < go0.ObjectCount; i++)
var surface = go0.Object(i).Surface();
if (null == surface)
return Result.Failure;
Plane plane;
if (!surface.TryGetPlane(out plane, tolerance))
continue;
var points = new List<Point3d>(go1.ObjectCount);
// Intersect the plane with each curve
for (var j = 0; j < go1.ObjectCount; j++)
var curve = go1.Object(j).Curve();
if (null == curve)
var curve_intersections = Intersection.CurvePlane(curve, plane, tolerance);
if (null != curve_intersections)
foreach (var intersection_event in curve_intersections)
if (intersection_event.IsPoint)
points.Add(intersection_event.PointA);
if (points.Count >= 2)
// Orders a set of points so they will be connected in a "reasonable polyline" order.
var sorted_points = Point3d.SortAndCullPointList(points, tolerance);
var polyline_curve = new PolylineCurve(sorted_points);
var object_id = doc.Objects.AddCurve(polyline_curve);
doc.Objects.Select(object_id);
doc.Views.Redraw();
return Result.Success;
Hi, Dale,
Thanks, but that’s still not what I want. I want to get a collection of line segments, each line segment passes only two points. See picture below! Ming
Hi, Dale,
I made the following changes from your code, and it almost works. I’m just missing a few corner points. What did I do wrong? (see picture below)
// Orders a set of points so they will be connected in a “reasonable polyline” order.
//var polyline_curve = new PolylineCurve(sorted_points);
//var object_id = doc.Objects.AddCurve(polyline_curve); //doc.Objects.Select(object_id);
for (var k = 0; k < sorted_points.Length; k++)
Point3d pointTo = sorted_points[k];
doc.Objects.AddPoint(pointTo);
if (k > 0)
