How to exponentially move points from a curve to transform it into an arc
Hi!
I want to exponentially move points from an original straight curve on the X axis where each point moves a little bit more than the previous one. I was thinking that maybe I could apply a mathematical formula? Not really sure how to do it.
I tried with graph mapper but i want something that doesnt not include one. I also tried by forming an arc but i want it to be the result of the points being moved first.
Thanks!
moving points from a curve into an arc.gh (10.5 KB)
moving points from a curve into an arc_re.gh (11.2 KB)
Thanks for the reply!
I was thinking maybe if someone had in mind a way of doing it without using a graph mapper and an exponential equation or something?
moving points from a curve into an arc_reV2.gh (13.5 KB)
if you want arc from circle you can use this
arc.gh (29.9 KB)
