How to explode custom doors within GH definition?
I wonder how to solve such a problem: there is a model with some custom doors, made with custom 3D blocks. Then, for some reasons I use a GH definition and I need to explode these doors for some further operations. With regular VA doors it’s quite easy. With custom blocks I cannot use them, as “data coversion failed from block to block”… Do you have any ways to solve this problem?
Cheers, Jaro
Hi Jaro,
You need to use a “Deconstruct Block Instance” from the “Blocks” output in the VisualARQ Explode component. Then you can obtain the geometry of that block with the “Block Decompose”. You will need to move the geometry of that block definition to the position where the door is located.
Hello Francesc,
Well, this should work. But it doesn’t… Maybe my blocks are a bit weird… :wink:
Anyway, I will try to modify these blocks, I really badly need your solution.
Thank you :slight_smile:
Cheers, Jaro
