How to exclude/extract data from a data set?
Hi, i am trying to exclude data from a data set, as an example: There are 4 lines in a row, but i want to select only 3 of them and use that data further for a array copy. So it should extract only the ones i need from the data?
So i dont want to use list item, but i want to extract the data from those lines with a list item component. With entwine you can combine two tree’s of data, but i want to extract to tree’s of data from eachother with a certain condition.
Regards,
Giorgio
Hi GiorgioR,
Based on the 2nd paragraph: Is this something you’re looking for?
FILE: 2020.10.30 - SelectDataTree.gh (8.2 KB)
Cheers!
Kaushik LS
Chennai, IN
Hi Kaushik,
That is exactly what i meant! Thank you very much for the reply and solution!
You’re welcome! :slight_smile:
Kaushik LS
Chennai, IN
