Hi to all,
I have a brief question regarding mesh-welding in grasshopper.
I have made a facet dome from points,
which I mesh in a specific simple way:
extruding all facets to a center point from which the facet dome was created, to obtain only triangle breps
I mesh these triangles*
However, the joint mesh ends up unwelded in many places.
If I use the ‘Combine&Clean’ component from Kangaroo, I obtain the vertex count I desire.
This appears to be an intermittent bug, where sometimes I obtain the vertex count I want, yet other times I push the vertex to which I extrude the facets a bit outwards, then weld, then I get the desired count; said ‘workaround’ didn’t work this time
See image:
File here, in case you want to look at it:
dometomesh.gh (12.8 KB)
*I chose to mesh them using the ‘Simple Mesh’ component in grasshopper
