How can I duplicate a Layout (PageView in RhinoCommon) via Python or Rhinocommon?
I am looking for a command that is similar to this UI function:
I did not find anything here:
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_DocObjects_Tables_ViewTable.htm
Would https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Display_RhinoPageView_Duplicate.htm work for you?
I thought this one just duplicates the object in memory. does it actually add a new tab to the UI ?
import scriptcontext as sc
vns = rs.ViewNames(return_names=False,view_type=1)
viewObj = sc.doc.Views.Find(vns[0])
viewObj.Duplicate(True)
fails with:
Message: 'RhinoPageView' object has no attribute 'Duplicate'
@dale I think there is a bug in RhinoPageView.Duplicate(True)
It creates a new Layout and duplicates the geometry, but the duplicated geometry stays on the previous Layout. the new layout remains empty. The old layout has duplicate geometry. Can you reproduce this using my above pythonscript?
I am on Rhino 6, 6.6.18177.16151
Hi @Goswin,
I am able to repeat this bug - looks like an easy fix.
https://mcneel.myjetbrains.com/youtrack/issue/RH-47249
– Dale
