How To do this?
In the above mentioned image I am working with a carved piller design and in top as well both side I have aligned all things now the first blue object from top I have aligned proper considering the both side object now I want to do the same for the rest so how can I do that such the space and alignment is common among them is equal.
You can just Copy the blue object snapping to a common point on the green ones, if that’s what you are talking about. This sounds like you would do well to go through the Level 1 Training Guide.
Would Array command be useful?
I can provide the rhino file or asset can you give me the guidence as I tried but the common sapcing from all side and all object is getting un equal so that is the main cause for this.
let me check for that
Array Linear comand and Stretch command may also be useful. The Stretch command has the Rigid option. With Rigid=No the individual objects will stretch along with the spacing of the objects. With Rigid=Yes the individual objects will not deform and only the spacing of the objects will change.
The Array command, since at least Rhino 8, has two modes: UnitCell and Fill. Fill simplifies arraying objects to fill a space.
