I’m working on a project in which I have to bend the rectangular ending of a pipe to a round pipe. I work with 1mm metal sheets and can bend them manually with a machine. I have problems designing the flat pattern in Rhino. In SolidWorks, there is this option: https://www.youtube.com/watch?v=K_76qGkatAo. How would you do that in Rhino?
In this picture, you can see what I’m basically aiming for.
Explode the rectangle and split the circle where the edges meet it, then use _EdgeSrf to create 3- and 4-sided panels, picking top and bottom edges first. If the base is square you can just create one of each panel and polar array them to speed things up.
But the next problem is that while working with a bending machine, the metal sheet itself has a thickness and bending it introduces a radius. Something like this happens…
(In Solidworks for example there is a feature where you can assign these properties; https://www.youtube.com/watch?v=Hvp8Cl6FI7s) What would make sense in Rhino? Extrude the surface to 0.5mm? Do you have any ideas?
