How to do "for each closed curve create a patch"
I have a group of closed curves that i need to fill individually. If I were to select all of them and run a patch it would treat them all as 1 object. How can i make it so that I can set multiple closed curves in a curve node and basically say “for each closed curve, create a patch”. They are also not connected so if theres a way to do a for each by connectivity maybe thats also an option?
attaching an image or a GH definition with internalized geometries is always of help to make others better understand what’s your starting point and what you want to achieve
maybe this is what you’re looking for, maybe not :slight_smile:
Yes thankyou! Just had to set to graft.
