How to display JSON extract in Shapediver
I’m trying to display a JSON extract via Shapediver. It work well in rhino but the display is not working in Shapediver.
I also tried to create geometry extract from JSON and same thing work well un Rhino display but not in Shapediver. Here is the file
CALL-S~2.GH (15.2 KB)
Thx helping me!
It seems the System.Text.Json package is not standard and needs to be installed on the servers.
You can force your script to require the installation by using this directive at the beginning:
#r "nuget: System.Text.Json, 9.0.2"
I tried this and made the script work on ShapeDiver. Note however, that it means the library has to be installed on the fly before running your script, which typically takes some additional time. We will pre-install the library on the servers soon, so this step can be skipped.
In my script I use boolean data extract from a JSON return for an automatic color change in my shapediver file. I use a Stream filter in grasshopper to change the color and it was running well in Shapediver before (from boolean directly from grasshopper) and its working well in Rhino
As you explain to me earlier this month. Can I force my script to require the installation ba a directive in my C# Script? (nuget" fonction?)
Thx!
Can you share a minimal script showing the issue you are talking about? I did not fully understand what the problem is from your message.
Here is the script
v6 simple pour shapediver .gh (35.2 KB)
