How to display different guides for different levels?
I’m still new to VA so I was testing out the new guides feature in VisualArq 3 for my column grid. I was wondering if there is a way to make it so that only the guides I drew on that level show up? Right now I’m using layers to control the visibility of guides, which is a hassle since I have two plans on a sheet that both need to show their respective guide lines, and that means I currently can only show one without the two column grids overlapping eachother in the plan.
Hi @Qiubai_Zhao,
That’s the default behavior.
Uploading: Guide Display Perspectivew View.gif…
Check your guide style, and make sure the Guide Model View is set to On “CPlane’s elevation”
