How to display components that are cut by Boolean?
When a component is Boolean cut or deducted by another component, how to display and view the cut part?
did you try the option delete or delete it manually?
When a component is deducted, does the deducted part no longer exist or is deleted by the program?
When I select the Delete option during a Boolean Subtraction operation, will I no longer be able to see the cut parts?
Hi -
There is no simple “Delete” option. The command has the DeleteInput and the DeleteCutters options. For more information on those, see the help file: BooleanUnion | Rhino 3-D modeling
there are not so many options, it can not be so difficult to simply try them… i really dont get those questions sometimes.
