When constructing a polyline in Ortho mode, guides appear along the axes in white. How can I turn it off?
When Ortho is disabled, naturally it is not displayed
Yes, I have been meaning to post about this as well but keep forgetting. I did not find a way to turn this off and it’s very annoying if you have your ortho set to something like 30°
They are called Hash Marks and it’s a new feature in Rhino 8. I haven’t figured out how to turn them off, I will contact support and repost when they respond.
Hello- thanks, I added
RH-80798 Ortho hash marks - setting to turn them off
I would like to be able to turn off ortho hash marks before V9. Definitely not a high priority item but they are annoying.
In the future any new features should have the ability to be turned off on day of introduction.
I had the same experience but after a while I found them really useful. I have my ortho set to 15 degrees (I can easily get 30, 45 and 90 degrees) and while working from perspective view it gets a bit confusing, but these marks helps a lot. Actually I was about to request to add additional detail to easily spot quadrants (thicker line maybe) - 0, 90, 180 degrees (and then I can turn the crosshairs off !)
Thanks for the tip. So indeed, through the “OrthoAngle 0” command, you can turn off the display or set your own values ​​​​that are necessary for snapping at a certain angle.
Added feature request RH-80807 Ortho hash marks: Additional configuration
RH-80798 is fixed in Rhino 8 Service Release 6 Release Candidate
