I have a block with variable number of outputs and at certain points in time I want to delete some of this ouputs in the run time and also deleting the wired connecting to other blocks.
I have used the following but I got an exception : object expired while solution.
“Params.Ouput[i].Recipients[j].RemoveAllSources()”
Is there a better correct way to delete the wire connection my block with blocks connected with my output?
