How to delete the border line from the layout
<img src=“https://global.discourse-cdn.com/mcneel/uploads/default/11358/f6ce37c85c8f47b2.png” width=“690” height=“388”
I’m really bad at Rhino
You cannot delete it but you can change it’s color so that it is the same as the background and/ or you can set its print width to none so that it won’t get printed.
I have to send it in pdf form so I’m going for the color change but how do I do that?
If you select a detail and then run Properties, you’ll see that the print width is set to “No Print”, which means that the border will not print.
Does this help?
:+1:
