How to delete colinear lines that are not identical
I have produced this 3D Voronoi structure and deconstructed it into its base lines (left picture), and I want to delete all the small line segments created along the edges of the bounding box (highlighted in green in right picture).
What I tried:
1- Since the edges obtained from deconstructing the bounding box aren’t identical to those in the Voronoi structure, I haven’t been able to treat them as duplicates to cull them out.
2- I tried writing different python scripts, but since I am only looping through the deconstructed points not the lines, all I could do was delete the points that fall along the lines I want to delete. But this doesn’t work in my case because this would also delete all other lines (not of interest) that are connected to that point.
  • find all orthogonal small edges, do this by converting them to vectors and selecting by length and when 2 components of the 3 (x,y,z) are equal to 0
  • collapse each small segment into a single point, do this by finding the mid point. Doing this also create 2 vectors, point from each ends of the small segment to the mid point
  • apply “point deform” to all other segments using the just created vectors
This would probably works better iteratively.
Or, delete those line segments where midpoint of line segment intersects the bounding box of the volume. Ricardo’s idea is more elegant though
