i did this beautiful vase, but now i want deform it.. rotate top and bottom but without move le middle of slide…any idea to do that ?
Tks per advance.
A.
2.gh (582.3 KB)
ok, i dont’ understand…join curves is connected to boundary surface…
if the file is behaving differently on your computer, so you see the fins/wings on your screen, it might be that you have uploaded a different verion of the same file?
oh, I forgot to mention that I’m on Rhino8 by the way, are you on Rhino8 as well?
“Wings” visible with Rhino 7.
ok, i’m on Rhino7. perhaps the diff.
i reload the file…i hope that will be good for you.
A.
2c.gh (77.2 KB)
Hi Leopold…
Tks for your answer, i’m going to study it. youy version seems to be more slowly…
I did it a sample myself…cool to compare
Yet another approach for this: I liked the original concept, but I thought the final result would be nicer with an added vertical section in the middle. So I made this design with no rotation to start, and then added the rotation of the center section. I actually prefer the shape with no rotation, so that’s what I’m going to print.
hi guys,
i liked these 2 versions, différent approach…i’m going to print them
i posted my last owner version…
