Hi guys,
I am trying to increase the width of the rectangles (horizontally) which are spread in 3D. I am using the approach of moving the vertical lines of the rectangle by the desired distance (let’s say 0.1 m; it has to be parametric). However, since the 3D has planes like xz and yz so I cannot use only x or y to move the lines. I have used a very complicated approach to move it by using both x and y directions for the move and in the end I am trying to close the curves to form enlarged rectangles by joining the moved lines.
Now, I end up with two types of rectangles with the same centroid (original and enlarged one) in one branch. I have used dispatch to separate original and enlarged rectangles but the same index (0) for enlarged rectangles in the xz & yz planes is not representing the enlarged rectangles in the xy plane. Is there any way I can select only the large rectangles?
Thanks a lot for your time and help!
Bests,
Problem1.gh (32.7 KB)
