Hello, are there some logic to make this out? I mean to do this without attractor or field one. Thanks!
You could generate the coordinates from a series of numbers using the Cross Reference component with one of the non-standard matching types. Lower Triangle or something.
I’ve included a couple of methods in the file attached. One is following something like Mr Rutten’s suggestion of using the cross reference component, although I’m not sure I made it in the most efficient way.
BoxDecay.gh (20.2 KB)
Thanks, I will try to find some other solutions
Let me play under this logic a little bit to see what comes out.
i thought those were called Qbert boxes
Damn:sweat_smile:
qbert cubes.gh (21.1 KB)
