How to create the 2 sided vial bottle?
I’ve created these curves for the vial. As you see it has offset curves for 2-sided glass properties. But when I revolve the whole curves, it creates a single-side vial. Why?
T.3dm (419.9 KB)
As the ends of each curve match the center of the revolution, there is not intersection between the resulting surfaces. that’s why.
To model a bottle with thickness, there is no other way than open it in some place, at the top, for example.
other way can be deleting the lines that connects each side of the bottle, resultin in two separate objects, for rendering purposes it works.
