Hi all,
I would like to create a surface from a sets of points (may be more than 20,000 points).
I am using _Meshpatch to create a mesh from points and then _MehsTONURB for surface creation.
When i used MeshTONURB, Rhino is showing an error says"The mesh has more than 20,000 faces. You might run out of memory and crash". Please see attached error message.
Is there a better way to create surface from point/point clouds?
Thank you in advance for any response!
