How to create round cap when using the Loft Command
I’m using the loft command to create this object, but I would like it to have a rounded point, verses the current flat point.
I’ve tried to use the fillet, and that works, but still not a real nice smooth point.
Any suggestions?
Thanks,
Kent
Loft Example.3dm (267.2 KB)
For a smooth tip, make sure that the last row of points and the singularity are in the same plane. You can achieve that with Loose loft.
Thank You… That did the trick!
Thanks again…
Kent
