How to create point cloud data from mesh?
Hello everyone,
I am opening step file and getting its mesh. Now that I have mesh object I want to write/create point cloud from the mesh. How can I achieve this
      string stepFilePath = @"C:\Users\d\Downloads\cube.step";
      RhinoDoc.Open(stepFilePath, out bool t5);
      var activeDoc = RhinoDoc.ActiveDoc;
      IEnumerable<RhinoObject> brepObjects = activeDoc.Objects.GetObjectList(ObjectType.Brep).ToList();
      List<RhinoObject> brepObjectsList = brepObjects.ToList();
      foreach (var obj in brepObjectsList)
          obj.Geometry.GetBoundingBox(true);
          RhinoApp.WriteLine($"Brep Object Id: {obj.Geometry.GetBoundingBox(true)}");
      Mesh mesh = Mesh.CreateFromBrep(brepObjectsList[0].Geometry as Brep)[0];
      RhinoApp.WriteLine($"vertices count: { mesh.Vertices.Count()}");
      return Result.Success;
Create a PointCloud Geometry with this constructor - see in the docs
public PointCloud(
IEnumerable<Point3d> points
→ “point cloud data”
or you can directly add the Pointcloud to the document - ObjectTable.AddPointCloud:
public Guid AddPointCloud(
not sure - is this what you where after ? hope it helps - kind regards - tom
Hey Tom,
thanks for replying. I should clarify more precisely. With this constructor and method it will create viewable point cloud. but this points we need to provide as input may be from vertices.
What I already know / have tried
  • Converting mesh vertices directly into a PointCloud (e.g. new PointCloud(mesh.Vertices)) is easy, but this produces a point distribution that depends heavily on tessellation and is not uniform.
  • For my use case, I need points sampled on mesh faces, ideally proportional to face area, with:
    • fixed point count
    • deterministic results (fixed seed)
    • independence from mesh vertex density
Current approach
Right now I’m manually:
  • iterating over mesh.Faces
  • computing face areas
  • sampling points inside faces using barycentric coordinates
  • adding those points to a PointCloud
This works, but I want to confirm whether this is the intended / recommended approach in RhinoCommon, or if there is an existing API or utility I may have missed.
My questions
  1. Is there any RhinoCommon-supported method or helper for uniform surface sampling of a mesh (not vertices)?
  2. If not, is manual face-area–weighted sampling the correct and stable approach?
  3. Are there any pitfalls with this approach in Rhino (performance, precision, edge cases)?
  4. Would you recommend sampling from:
  • the mesh directly, or
  • converting mesh → Brep and sampling from Brep faces?
there are some nice options for meshing / remeshing.
but not sure if @DanielPiker did ever expose it nicely in rhinocommon.
have a look at this topic.
What is the benefit of having a point cloud instead of nurbs?
