How to create ObjectBase from geometry
Hi all i try to get GeometryBase from Geometry to use GeometryEquals to delete identical geometry because if one object gets selected more than ones creates different Object.Ids…so Sets are not possible otherwise i could write set(list1+list2) to only different objects.
But i dont know how to create a geometry base from a Geometry.
small example is very appreciated
Hi @flokart. Objects that inherit from GeometryBase can be geometrically tested with GeometryEquals like this:
Rhino.Geometry.GeometryBase.GeometryEquals(Curve1, Curve2)
or more specifically
Rhino.Geometry.Curve.GeometryEquals(Curve1, Curve2)
You’ll get a True/False return value. Hope this helps.
Thanks David,
i was confused because
rh.Geometry.Curve.GeometryEquals(GeometryBase,GeometryBase)
ask for GeometryBase and not for the Geometry…so GeometryBase is the Geometry and cant be constructed like a AreaMassObject for example?
