Hii!
How can i make meshes that fill in the top shapes/squares of the frame?
(here you can see it in red, but it needs to be all over the frame ofc
Thank you
Jessica
Hii!
Thank you
Jessica
Make a surface from 3 or 4 points snapping to your frame corners then mesh those surfaces to your desired mesh density-
Do I have to do that seperate for every surface? Because it needs to be with the surfaces on the outside (in this shape). So all over the frame
most likely yes, unless you do some sort of clever Grasshopper definition…
