How to create Grasshopper Line SDL using rhinoscriptsyntax?
by :
Start point
Direction
Length
by :
Start point
Direction
Length
Here’s one way:
s = 0,0,0
d = [1,1,0]
l = 5
vec = rs.VectorScale(rs.VectorUnitize(d),l)
rs.AddLine(s, rs.PointAdd(s, vec))
-Kevin
In Grasshopper, using the RhinoCommon is perferrable.
import Rhino.Geometry as rg
def create_line(start, direction, length):
vec = direction
vec.Unitize()
return rg.Line(start, start + vec * length)
if __name__ == "__main__":
s = rg.Point3d(0, 0, 0)
d = rg.Vector3d(1, 1, 0)
l = 5.0
a = create_line(s, d, l)
Indeed, and fully skipping middlemen, there’s also the overload that takes start, direction and length directly:
Thank you all.
rg.Line(Point3d, Vector3d, length) works just fine.
Function approach is interesting. Why in Grasshopper RhinoCommon is preferable and when rhinoscriptsyntax used?
rhinoscriptsyntax was meant for scripting in Rhino and often introduces some confusion when used in GHPython, like for instance having to deal with GUIDs (unique references) instead of geometry objects directly.
