Hi everyone, i hope anyone can help me with this script, so i want to make cycling track but i dont know how make the track that got different angles smoothly,
Would take a lot of time to “work” on your script. But some suggestions (how I would start this):
Most basic is the black oval . This is planar, has precise measurements. Two lines and an curve (what is it? circular, ellips? Of something else)?
Just design 1/4 of curve, then mirror in two steps).
Divide the curve (or segments of the curve) and with perp frame place planes there.
Outgoing from planes lines for the first tracks around (3 and 6 degrees). Use rotate plane to get the correct degrees
Connect the endpoints of these lines with an interpolate curve.
Then the track with the 12 to 45 degrees.
I would start with the known parts first (same as above) and make the lines at the 12 and 45 degrees point.
It is not clear how the curve in between is calculated, most simple is to consider it as segments of an ellipse.
the curve on the floor is a circle
the curve of the 3 degree and 6 degree lines are also circular.
the curve going from 12 to 45 and back is elliptical.
thinker a bit about it and you will find the elliptical center points and can draw the outer/upper curve.
