Option Explicit
'Surfcae curvature analysis at a point
Sub SurfaceCurvature
Const rhObjectSurface = 8
Dim strObject, arrPoint, arrParam, arrData, pt
strObject = Rhino.GetObject("Select a surface", rhObjectSurface)
If Rhino.IsSurface(strObject) Then
arrPoint = Rhino.GetPointOnSurface(strObject, "Pick a test point")
If IsArray(arrPoint) Then
arrParam = Rhino.SurfaceClosestPoint(strObject, arrPoint)
If IsArray(arrParam) Then
arrData = Rhino.SurfaceCurvature(strObject, arrParam)
pt = Rhino.SurfaceDraftAnglePoint(strObject, arrParam)
If IsArray(pt)Then Call Rhino.AddPoint(pt)
If IsArray(arrData) Then
Rhino.Print "Surface curvature evaluation at parameter (" & CStr(arrParam(0)) & ", " & CStr(arrParam(1)) & "):"
Rhino.Print " 3-D Point: (" & Rhino.Pt2Str(arrData(0)) & ")"
Rhino.Print " 3-D Normal: (" & Rhino.Pt2Str(arrData(1)) & ")"
Rhino.Print " Maximum principal curvature: " & CStr(arrData(2)) & " (" & Rhino.Pt2Str(arrData(3)) & ")"
Rhino.Print " Minimum principal curvature: " & CStr(arrData(4)) & " (" & Rhino.Pt2Str(arrData(5)) & ")"
Rhino.Print " Gaussian curvature: " & CStr(arrData(6))
Rhino.Print " Mean curvature: " & CStr(arrData(7))
End If
End If
End If
End If
End If
End Sub
'Surface contouring depending on the draft angle
Sub SurfaceDraftAnglePoint(strObject, arrData)
Dim contourDst
contourDst = 2 * pt * Rhino.ToRadians(dblDegrees, Angle) * sqr(2 * arrData(6) * 0.1 - 0.01)
arrContours = Rhino.SurfaceContourPoints(strObject, contourDst)
If IsArray(arrContours) Then
For Each arrPoints In arrContours
Rhino.AddPointCloud arrPoints
Next
End If
End Sub
Hi @GHumera,
I am not sure I understand what you want to do and why. Can you explain further what problem you are trying to solve? Do have a sample model you can share?
– Dale
Sir, i have 3D surface model attached below and i need to create contour of
this model based on the draft angle of the surface model.
Thank you in advance
Hi GHumera - can you attach your model again? It looks like nothing is attached to your post.
Hi, sir this is my model
