K113
(K)
#1
Hi.
I should create Cage Box for object.
so I used below code.
ON_MorphControl* control = new ON_MorphControl();
CRhinoMorphControl* control_object = new CRhinoMorphControl();
control->m_varient = 3;
control->m_nurbs_cage.Create(bbox,
degreelist[0], degreelist[1], degreelist[2],
cv_counlistt[0], cv_counlistt[1], cv_counlistt[2]);
control_object->SetControl(control);
doc->AddObject(control_object);
RhinoCaptureObject(control_object, (CRhinoObject*)captive)
To create cagebox and to capture object was success.
But after moved control point of cagebox, the following problem occurs…
please help me.
Moved to Developer category.
dale
(Dale Fugier)
#3
Hi @K113,
Have you seen this SDK sample?
cmdSampleCageEdit.cpp
Sorry, but you have not described your problem enough for us to help. What are you trying to do, exactly, and why?
Thanks,
– Dale
K113
(K)
#4
Hi @dale ,
Thank you for your reply.
I have seen this SDK sample.
This sample is to create control point on curve.
I found out know when create control point on curve, use m_nurbs_surface0, m_nurbs_surface, SetCV.
but I can’t understand property of m_nurbs_cage, m_nurbs_cage0.
I want to create control point on bounding box and move control point on bounding box for object.
so I used ON_MorphControl, m_varient = 3, RhinoCaptureObject.
To create Cage box and control point on bounding box and to capture object was OK.
But when move control point, object get out of bounding box and grow in size.
I want to know how to create to work normally cage box(bounding box).
if you know how to set normal cage box for c++, please let me know.
Thank you.
