Hi I try to find out how I create a 16mm circle or hole oriented perpendicular on a non planar surface. Is there a way to create it, lets say as the example I show bellow? I have draw a line where I want to have the centre off the hole/circle.
A.3dm (2.7 MB)
Since the surface is planar, probably changing the Perspective view construction plane using the Cplane command and either the Object or 3-point option to match it to the surface will be the easiest.
There are other options too.
Thank you so! Exactly that I needed, and found out how to use to namedcplanes.Are there alternatives ways? I use orient or the one view on planar surfaces but on non planar?
Thank you so again
Hello- if you need the line, then Line
> Normal, then Circle
> Around curve may be what you need.
Oh that was new for me. Both cplane and line normal workflow are so useful.
Thanks for the help!!!
