How to Create Accurate Mitre Joints Between IndividualPanels?
Hello everyone,
I’m currently working on a geometric (low-poly) horse sculpture in Rhino 8, made from multiple individual stainless steel panels, each 3 mm thick.
The panels meet at different angles, and I need to create accurate mitre joints along their shared edges, so that they fit together perfectly without gaps or overlaps before welding.
I can already create the individual planar surfaces and give them the required 3 mm thickness using OffsetSrf. The problem is achieving the correct bevel angle on each panel’s edge.
I’ve tried several methods, including Trim, BooleanDifference, cutting planes and ChamferEdge, but I haven’t found an efficient and reliable way to achieve the result.
What I’m trying to achieve:
  • Keep every panel as a separate solid.
  • Maintain a constant thickness of 3 mm.
  • Automatically calculate the correct mitre angle between adjacent panels.
  • Create matching bevelled edges so that the panels fit together accurately.
  • Ideally, apply the process to multiple panels without having to manually calculate every angle.
I’ve also come across Grasshopper solutions involving NGon, but I have no experience with Grasshopper and would appreciate guidance on a simpler solution, if one exists.
I’ve attached a sketch illustrating the result I’m trying to achieve.
My question is: Is there a Rhino command, plugin or Grasshopper definition that can automatically generate these mitre joints between adjacent sheet metal panels while keeping them as independent solids?
Ideally, I would like to obtain individual 3D panels with the correct mitred edges, ready for fabrication.
Any advice, tutorials or example files would be greatly appreciated.
Thank you very much for your help.
Best regards,
Pablo Justo
Hi Ares,
I think there’re several approaches to achieve this. One would be moving the overlapping edge (MoveEdge, or subselect edge and move with Move) back to the intersection of the two panels A and B. Do this for the edges of both panel A and panel B. From your screencast I see there are more overlaps, you can use boolean operations to trim these off.
Edit: forget the boolean stuff, when the edges are moved the panels don’t intersect anymore
Hi Ares,
Here are two possible approaches with your curved panels:
  1. With your curved forms and varying angles it is likely that creating panels as surfaces and offsetting to get thickness you will not get full intersections of one panel with another. Don’t create solids, just inner and outer faces, then Extend the surfaces sufficiently to get full intersections. Create an intersection curve from each pair of surfaces. Extend the curve on surface twice, once for each surface (the ends of the surfaces probably won’t line up so you have to do this to ensure the next step works. Then use the extended curve to trim each surface. You’ll find this a lot easier to manage if you put inner and outer surfaces on separate layers… Finish by placing a line between each pair of inner and outer corners and sweep and join the edges to complete the plates.
  2. Create the outer surfaces without worrying about thickness. Join them (make sure all joins are tight by checking for naked edges) and use Shell to add thickness. Provided your shapes are amenable, you should get a closed polysurface with inner surfaces exactly adjusted to the intersections. You can then explode the polysurface and add the edges as in 1 above. [Edit: This is not going to work well with your shapes where they taper to less than 3mm.]
HTH
Jeremy
Personally I use the bit barbaric method of:
1 - _Intersect to get the intersection curve of the two breps (preferably in another layer)
2 - Create a rectangular surface that fits the curve (you might need to scale the rectangle up to encompass the entire plate)
3 - _BooleanSplit to cut off the bit of the volume with the surface
Hi @ARES1
We’re preparing to release our in-house plugin publicly, but we’ll need a little more time to do so. It takes time to add features that serve the general market in addition to our own needs.
If you’d like to outsource this project before we release the plugin, we’d be happy to take it on.
