Hi all,
Following this topic (How to create a toposolid - Rhino.Inside / Revit - McNeel Forum), I have another question I can’t find a solution to:
What if I want to build a toposolid with a non planar boundary?
In the original workflow in the previous topic, the toposolid is defined by a planar boundary and some internal points.
In my case I also have border points (3D, defining the 3D border)
If I follow the previous workflow the result is bugged: the points on the border are randomly not taken, giving me a bugged result.
How can I correctly insert them?
If I use the 3D boundary instead of the planar projection, and only the internal points, I get an error saying that I need a planar boundary curve.
So where and how should I put those 3D border points? I ran out of ideas, does anyone know how to do it?
Thakns in advance
