Whenever I try the blend curve command, I end up with something like this:
How can I get a perfectly symmetrical aligned curve without lots of clicking and manual tweaking?
Hello - Flip 1 would help here, and setting the selection to use the curve ends at selection time, and not the pick point would be best.
That was quick. Thank you.
I still haven’t gotten used to looking into the command line for options… especially when I knew that this command in particular had an options window.
