How Can I create a smooth single surface from polysurfaces?
Create single surface.3dm (3.1 MB)
Hi Sajesh,
I am not an expert. But normally, I would draw curves along the outer four edges of the shape, using InterpCrv. Then Edgesrf to create a single surface, using the four crvs I have drawn.
You won’t get 100% same shape, but something close.
How much experience do you have with Rhino?
The geometry appears to be triangular mesh which was converted to surfaces, possibly using the ToNURBS command.
Patch
may be useful. Curves along the outer edges will also be needed to either trim the results of Patch
or to create a starting surface for Patch
Curves along the edges can be created by first joining the surface/polysurfaces into as few polysurfaces as possible. DupBorder
to obtain polycurves around the borders of the polysurfaces. The result will be polylines/deree 1 curves. Explode
the polylines and delete the lines which are not on the border of the object. Join
the remaining curves. FitCrv
to obtain degree 3 curves with fewer control points.
If you have the original mesh then use it as the source of points for Patch
. If the original mesh is not available first Explode the polysurfaces into individual surfaces. Then ExtractPt
the control points of the individual surfaces which for these particular surfaces are the corners. (In general control points are not just the surface corners.) If the extracted points are in point clouds Explode
the point clouds. SelDup
to select duplicate points and Delete
the duplicates.
